Author Topic: Newly added tracks do not show Title  (Read 518 times)
63blonde
Everytime I have it scan for new music it ads tracks but no Title shows up. I can right click on the line there are at and select play, I then can see what song is playing in the bottom bar. I have the most current version for Windows 10 installed.
63blonde
I fixed it. Under Tools go to Advanced, then  Rescan All Files and the titles appeared.
That shouldn't be necessary, and I'm pretty sure that command is just a manual way to trigger what should be happening when you scan for new tracks anyway.
63blonde
Well nothing else I could figure to try has worked and I only stumbled on that way but just trying whatever I could.
