You could probably just select Help > About and check the version number, but to confirm otherwise:
...Portable has the advantage of containing all of MB in one directory which makes it much easier to backup and/or move to another PC by simply copying MB's directory.
Wow, phred, thank you. I had missed? or never read this distinction, this advantage, anywhere previously as clearly and simply as you write it here. It should be noted in the installation page: I had always read the "other" language on the Installation page as not for me since I have MB installed on two non-partitioned or otherwise-complex systems -a NUC and a Surface Pro, each with its own "system" drive. Years ago I suggested somewhere that a clear explanation of the versions be included/head the Installation section of the Wiki FAQ, and this meaningful clear sentence should be there.
I am now going to install the Portable version on a third system, a second NUC, this week, because of this now/finally-understood by me advantage.
I have a couple of related questions: 1) What happens if I install the latest Portable version on top of an Installer 3.4.8033 version on my current NUC? (How) Could I take advantage of this move advantage thus for my new system? (My Surface Pro already has the latest Installer installed.)
2) Might you have a similarly clear sentence for "Installer has the advantage(s)...xxx"? (In my continuing naivete, I now wonder why an Installer version is available, though I'm confident that there are very good reasons.)
Thank you.
