Hello there!
Been using auto-export for quite some time, works without issue for me. But I'd like to know is there an option that I don't see, that allows to define how the songs are sorted in those exported .m3u playlists?
As I see now, they seem to sort by adding time (from oldest to newest). I'd like it to be sorted by other fields. In a Playlist view the songs are sorted the way I need them, but upon automatic export, MusicBee seems to use some other sorting default.
Funny thing is, if I manually export that same playlist with "Export" function, the sorting I have in a view is preserved.
Will appreciate any advice!
PS Tried to look for this here on the forum, only found
this thread, but there's no answer there.
