Author Topic: How to RE-scan library for non-existing files?  (Read 453 times)
clsven
When I started recently MB a popup appeared:
"The follwoing files no longer exists at their expected location - remove them from the library?"
I clicked "NO" button to check the problem at a later time.
Now I have time to check the situation.
But when I launch MB again the popup does not appear again.
It seems to me that MB show conflicts only 1 time.
How can I tell MB to re-check the library for non-existing files?
While displaying your entire library in the library explorer
Tools->Tagging Tools->Other 'Files to Edit' Filters->Show Dead Links
clsven
Ok, and how do I open the "Library Explorer"?
When I open "Music Explorer" and click on your suggested sub-sub-menu nothing happens
When I open a new tab I miss an entry "Library Explorer"
He just means open your Library tab where your holdings are displayed.  Then see below:
