Author Topic: Copy date from MB to another version of MB (26/03/2023)  (Read 470 times)
Flourgrader
Hi,Everyone,
I have MB on my main PC.
I have set a list up of radio stations I listen to.
I have a laptop with a new installation of MB on it.
I would like to know in which file the information is
stored for the radio stations so that I can open the file and copy the
information across to my laptop?
Thank you.
Last Edit: March 26, 2023, 09:19:27 AM by Flourgrader
karbock
Hello Flourgrader,
Your radio stations are stored in the main library file: MusicBeeLibrary.mbl (just checked in my version).
For its proper location (installed vs. portable), refer to this post, section B.1.
May I suggest that you change "date" for "station list" in the thread title, so that it reflects the accurate content for future readers?
Search
  Forum •   Wiki
Tips
MB File Paths •  Update Patches
$Functions() •  Regular Expressions
Tag Symbols •  Tag Mapping
for radio stations, if you click the Radio button, there is an Export and Import Stations function that might do what you are looking for
Flourgrader
Thank you Steve & karbock for our
advise, it was very much appreciated.
Flourgrader
I just used import and export on the radio button.
Could not be easier than that.
Thank you Steven..
