Author Topic: Add-On to Skip Songs?  (Read 216 times)
Dalinar
hi, is there any add on that can skip tracks based on some tag info - for example keywords in the track title?
There's no such add-on, but you can create an auto-playlist or filter with the criteria...
[TAG] does not contain [keyword]
Dalinar
thanks, what does "or filter" mean? can that be applied to any playing playlist? or each playlist must be edited for that?
It is a filter on the entire library. It will only show, or only not show, tracks to meet, or do not meet, the criteria you set up. I doesn't not filter the current playlist.
I suggest you check the Wiki for more information.
