Author Topic: Musicbee repeats the Song but "Repeat One" is not selected  (Read 211 times)
mofodesign
Musicbee does not play the playlist, but repeats the current track. Only if I manually skip, then the next track is selected. The repeat function is off.
I have no idea where the error lies.
Can anyone help? I would be very grateful.
Thanks,
Martin
do you have 'playback follows cursor' ticked in the player preferences?
What is your (exact) MusicBee version?
Are the files local?
When did this start to happen?
mofodesign
I use the version 3.4.8033.
The files are on a synology server, but this error occurred only a few days ago and since then it always plays only one song - in an endless loop.
I think to recall this has been reported in the past by somebody else who was using a NAS.
Perhaps see if there is a (network) relation with that?
Also, I would suggest updating to MusicBee v3.5
mofodesign
Ok, update I put in, that didn't help, but ....
... I may have found a cause, though not a solution. Actually I use the Musicbee UPnP app, which worked fine so far. As a player I then use my Naim Unitqute. If I set the player back to "Directsound", the problem no longer occurs.
But I still have no idea how I could change this with the UPnP player, or what could have changed.
