You can also use hotkeys, but toolbar commands could look like this
thank you for your answer
, it works nicely but not in miniplayer , is there a way to show the toolbar in the miniplayer? or can I customize the player controls bar instead?
I also tried using hotkeys while using the miniplayer but it didn't work because I was using other apps at the same time (and it was in the background) , I had to click on musicbee miniplayer first and then use the hotkeys
