I am back!
That is fantastic - thank you! It is much easier to use now.
I have some (basic) coding experience, so duplicated your XML file and am looking at it using a free XML editor. I searched for the HEX value of one of the scrollbar colours as I am really interested to understand how it works. Searching for #dadada /and then 218, 218, 218 (I used PowerToys to identify the scrollbar colour, I found the code in XSL Output, but not in tree view.
I was going to change it to 232, 70, 12 as an experiment, but was unable to edit manually or via Search and Replace.
Could you tell me how to edit it?
Many thanks again for helping me :-)
Sarah
