I'm having a strange problem with the $if(<field>=<field>,true-value, false-value) function. I'm trying to create a template that adds some information if <year> is different from <original year> (basically add country and mastering). However, I can't get it to work, as can be seen in the screenshot.
Here are the information in Tag Inspector:
Isn't it strange that the equal sign and less than sign give the results they do?
