Author Topic: New Playlist  (Read 302 times)
familybond
I must be a bit dense but after an hour or more, I still can't work out, step by step, how to create a new playlist.  I have tagged what tracks I want on it, but cannot see how I get these to be the playlist.  Any help really appreciated.
Dojando
In the panel "Playlist Directory" make a right click. Now select "New" at the bottom and from there you can chose to make an auto Playlist or a normal playlist.
An Auto playlist will automatically add Tracks that meet specific criteria where as a normal playlist just need manual editing / adding / removing.
since you have tagged the songs that are supposed to go into a playlist, we will do the automatic one:
So, click on the "Auto playlist" button.
Now a new window has opened.
From here it should be relatively self-explanatory. If not, tell me and I will try to help further.
Once a static playlist is created:
1. Select Tracks
2. Right Click->Include in Playlist->{{Select One Or More From The List}}
You can also drag and drop tracks onto a playlist in the left pane.
https://musicbee.fandom.com/wiki/Playlists
@familybond-
Please do not create polls if you don't know what they're for. I have removed it.
Last Edit: March 07, 2023, 01:58:03 PM by phred
