Look at this screenshot. It's searching my WHOLE J drive for the missing audio file locations.
https://imgur.com/a/N1hTCznI have a question for this forum titled "Questions". Why can't we provide musicbee with a starting root directory from which to scan children folders/files for audio? This would mean I could tell it to search J:\Gets Backup\Projects\ and then it would have found all of the content within 2 minutes. Instead it searches the WHOLE of each drive which could take 20 minutes to a couple of hours since I have about 5tb of content in total across the drives. How is that reasonable?
To top it off, it only found 1/3rd of the content. So I have to manually relocate about 300 songs, even though they are all under a single root parent directory. Incredible! How can it be this bad at searching? It found some of the files under the correct directory. After it did the auto search, I manually matched about 10 that had the EXACT same names, and so do the rest of the missing 2/3rds. So I don't see how it's skipped over them. I've tried redoing the auto search 4 times and it's still not finding them.
