The version 3.5.8429 is crashing on me everytime I try to open the Web Browser. The error log is as follows;
30/01/2023 18:13:37 - 10.0.22621.0 - 3.5.8429.34057P - System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.IO.DirectoryNotFoundException: Could not find a part of the path 'C:\Program Files (x86)\MusicBee\AppData\ScrobblerBrainz\scrobbles'.
at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.FileSystemEnumerableIterator`1.CommonInit()
at System.IO.FileSystemEnumerableIterator`1..ctor(String path, String originalUserPath, String searchPattern, SearchOption searchOption, SearchResultHandler`1 resultHandler, Boolean checkHost)
at System.IO.Directory.GetFiles(String path)
at MusicBeePlugin.Plugin.ReceiveNotification(String sourceFileUrl, NotificationType type)
at #=z5UiS6Z9kiWbVG5HpnA==.#=zEt5MgMXhKNl6()
