Author Topic: Reverse Sync to Computer (Poweramp)  (Read 1870 times)
MrVain712
Hello,
i´m using Poweramp (Android 13), MusicBee Wifi Sync an MusicBee on Windows 10.
I want to sync the Playlists which i have created on Poweramp with MusicBee on my Computer. Is that possible?
On MusicBee Wifi Sync is the option "Reverse Sync to Computer - playlists" greyed out, the same on MusicBee on my Computer. What i can do that it works?
Babydoll32
Nobody can help you, cause it doesn’t work.
2-way sync is only possible with Wifi, but just partial.
