Ok, thank you quick response! i will search for the information and try to make it work.
Reason for starting this new topic is that if you use the forum SEARCH engine ex. 'CLICKABLE Web Links' it shows nothing.
I was searching with always no results.
If you use google 'musicbee forum CLICKABLE Web Links' it will find the post.
