Great, thanks for fast support. Created one for 'last character' and for 'first'. They work fine.
Do you consider to create such preset in the future, to include in your set?
A combined one, where you can select variables as first, last, 1, 2, 3, 4, 5?
Greetz
PS:
One small display issue that you might be able to find solution for:
You use marroon as the font color for 'new value'. But (specially if I only want to change ONE file) I cannot read the new value.
Because my default color in Windows for highlighting a selected word/line is RED...
So there is no contrast between your font and my background.
