redwing, two your requests are implemented now. Download beta version of plugin from the 1st post of this topic.
Thanks for implementing my requests! I downloaded it and did some tests, but it didn't work well. A preset I set up (Swap first and last name adding custom text) was applied to tracks that don't belong to the selected playlist. And the preset itself wasn't working properly. It wrote in a tag differently from what was shown at preview. At last it was writing and rewriting constantly in some tags only to freeze MB. When I restarted MB, the playlist selection box was gone. Overwriting the new dll file didn't make a difference. So I ran MB with the previous version of dll file, exited, copied the new dll file, and restarted MB, this time I was able to see the box again.
Anyway, are you gonna add some more auto-apply options in addition to playlist, or that's all?
As for the new presets (combine and split tags), they looked great although I didn't actually test them. After looking over them, I got another wish, but it might take some time to implement. So just think about it.
Currently each preset allows the user to configure up to 5 steps. That's great, but only if you're familiar with regex. Otherwise, it won't be easy to utilize those step boxes. So how about allowing the user to select (and configure) another preset as a step by offering a preset selection box for each step from 2nd step?
Anyway, I'm looking forward to a bug-free update version
