And thanks for continuing development and support for your plugin.
Yes. Thank you boroda for the greatest MB plugin and for the continued improvements.
And wishing all forum members good health and good times in 2023 and beyond.
While I haven't had time to test the latest improvements to AT&RT, I do want to offer up a comment or two based on what hiccup has stated.
Since any audio I listen to via my PC is through headphones, I also immediately disable all Windows/Applications sounds upon installation. The audio warning may be helpful for some, but it won't do me any good. Nor will it help hiccup.
I have often been the victim of not realizing I have clicked a preset's checkbox and all of a sudden experiencing unexpected behavior. Double-clicking -may- prevent that, but I also think a visual warning would be better. I often double-click on things that don't need to be double-clicked. My suggestion would be to take the top line of the AS&R window ("Select preset...") and split it into two lines. The first being the current first sentence, which would also be there. Then on a (new) line underneath, something like "Some presets have been activated and will be automatically applied. Tick the box to see which ones are active." Obviously this warning should only appear if the user has presents enabled.
I think a combination of what I suggested above (which basically is a static warning) and a brief popup warning when a preset is ticked/double-clicked would make it very clear that a preset will be automatically applied.
