Author Topic: Additional Tagging & Reporting Tools  (Read 934325 times)
some visual glitches are fixed. also, highlighting of changed tags in most commands is back (because there is untickable option 'highlight changed tags' in plugin prefs):
https://www.mediafire.com/file/null/mb_TagTools_latest.zip/file
@boroda: this doesn't look like a valid MediaFire link. And comes up with:
sorry, here is correct link:
Thanks for correcting it.
Using today's update (5.4.8208) with MB 3.5.8205 P, I'm finding that is a selected preset has no files that meet the criteria, that upon clicking the 'preview' button AS&R locks  up. All presets are grayed out and the only way to exit AS&R is to 'x' out. 'Save all and close' will also exit AS&R.
I've been testing with the two "Remove leading zeros in  Tag 2>" presets.
Let me know if you need more information.
i can reproduce this. will look at this issue tommorow.
Not an "emergency" so take your time. Thanks.
iamambuser
Current error message
MusicBee v3.5.8157.35511D  (Win10.0), 22 Jun 2022 10:16:
System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.NullReferenceException: Object reference not set to an instance of an object.
   at MusicBeePlugin.SettingsPlugin.InitializeComponent()
   at MusicBeePlugin.SettingsPlugin..ctor(Plugin TagToolsPluginParam, PluginInfo aboutParam)
   at MusicBeePlugin.Plugin.Configure(IntPtr panelHandle)
   at #=zCJ5ZapFPlFl7hsQxGA==.#=zFyIrpRo=(IntPtr #=z5gr9m3RiL7fx)
do you see message "System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation" on plugin initialization (on mb startup if plugin is enabled)?
The only way I know the plugin failed is because 1. AT&RT does not appear in the "Tools" menu and 2. when I check it in my plugins menu in preferences and click configure the above error message pops up. Otherwise, there is no indication that it has failed.
can you upload (or pm) your mb_TagTools.Settings.xml? i'll try to reproduce the bug.
iamambuser
PM sent
