Author Topic: Additional Tagging & Reporting Tools  (Read 932172 times)
@phred, enter tag exclusions separated by ;; in the list at the bottom of asr.
And can you please make the window location persistent when you have the change? Thanks.
of course, its some kind of beta at the moment. :)
Ahhh yes. You've mentioned that before - you don't make the window persistent until you're out of beta. Thanks.
Is it not possible to offer this file in a location accessible without having to create a (mediafire) account ?
It is not necessary to register on MediaFire. I clicked on the plugin link and it took me direct to the MediaFire page with a window to download. Click it and it downloads. I did it yesterday, and I just tried it again today.
Darwin4Ever
Weird, tried it again and now it works without credentials. The first I tried it I had to enter a Username/PW
Thanks
@boroda...
Perhaps I'm mistaken, but I seem to recall that when using the "Change Case" module, the "New Tag Value" column showed tracks to be changed in blue. That doesn't happen in the version release today. Perhaps in the version released yesterday also, but I hadn't checked it. Nor is the color showing in AS&R proposed changed tracks. I apologize in advance if I'm only imagining it used to do this.
  • MB Version: 3.6.8849 P
@boroda
 I think I found a bug in the new version  :o
When you try to access a <Temp #> tag more than once, the regex is applied but all values from the source tag are copied over (see step 2)
all the values of Lyrics? have been appended to the tag:
If I change the output of step 2 to another tag:
only the correct regex output is appended to the tag:
@boroda...
no, you are not mistaken. its intentional change, but i'm not sure what is better. I think i'll revert it back.
Of course -I- think having the coloring is better as it calls attention to the fields that are going to be changed. Which helps me untick tracks that I don't want to change.
Unless you removed it due to some functionality issue, I'd really like to see it restored.
WimYogya
Hi all,
Allow me a typical Dummy's Question: Almost 10 yrs (?) a MusicBee user, including ATRTools.
Been inactive for a couple of months due to sight problems - but all ok now after 2 operations!
Had 2x a pc crash too in the meantime.
So now...
I reinstalled MB again, but cannot find how to install the ASR plugin again.
Absolutely not even an idea where to search.
Once I have it back I am sure I will re-teach myself again how to use my favorite features.
But how to begin?
UPDATE: I did find and downloaded the newest ASR-zipfile, unzipped it in a special folder.
But then? No idea anymore...
Also: there is still an ASR button in my toolbar. Totally blank about how to link ASR to that button.
An informative installation/startup link will already be helpful!
Thanks - and sorry...
Wim
Last Edit: February 20, 2019, 05:37:45 PM by WimYogya
WimYogya
retired Dutchman (1944) in Yogyakarta, Indonesia
But how to begin?
From the add-on page, click the download link and download the ZIP. (Your post update shows you did this)
In MB: Edit->Edit Preferences...Plugins...Add Plugin (upper right) and find the ZIP you downloaded
Using MB 3.3.6987 wtih ATRT version released Feb 15 2019...
I'm finding that the width of the columns in 'preview' do not remain persistent. When I open ASR they're bunched together and I spread them apart, run a preset, close ASR, reopen it and the columns are bunched together again.
Thanks.
