could you give me an example of this strange backup path?
10.0.14393.0 - 3.0.6118.33091 - System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(String filename) at MusicBeePlugin.TagHistoryPlugin..ctor(Plugin tagToolsPluginParam, String[] trackUrlsParam, String[] trackIdsParam) at MusicBeePlugin.Plugin.tagHistoryEventHandler(Object sender, EventArgs e) at System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs e) at System.Windows.Forms.ToolStripMenuItem.OnClick(EventArgs e) at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e) at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e) at System.Windows.Forms.ToolStripItem.FireEventInteractive(EventArgs e, ToolStripItemEventType met) at System.Windows.Forms.ToolStripItem.FireEvent(EventArgs e, ToolStripItemEventType met) at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea) at System.Windows.Forms.ToolStripDropDown.OnMouseUp(MouseEventArgs mea) at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ScrollableControl.WndProc(Message& m) at System.Windows.Forms.ToolStrip.WndProc(Message& m) at System.Windows.Forms.ToolStripDropDown.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
I've installed another portable MB for test, but it gives the following error for "Track Tag history" command. Strangely the command is working fine in another MB. Both are with the latest patch and plugin.
it seems that there is no 'missing artwork.png' file in 'plugins' folder.
- If there were changes, show those tags and values only on the popup window upon clicking on the command.
the ".Master Tag Index.mbi" is just a master index file, it must not be very big anyway.
Quote from: redwing on May 13, 2016, 12:18:31 PM- If there were changes, show those tags and values only on the popup window upon clicking on the command.This is what I suggested. But currently it shows all tags, not just changed tags. Then the user has to read all tags to find out what's changed.
Quote from: boroda74 on October 01, 2016, 11:49:11 AMthe ".Master Tag Index.mbi" is just a master index file, it must not be very big anyway.I am still concerned about the file's size which keeps growing whenever a backup is made even without any changes from the previous backup. Why does it keep growing without any changes in the library?
10.0.14393.0 - 3.0.6118.39208 - System.IndexOutOfRangeException: Index was outside the bounds of the array. at MusicBeePlugin.BackupIndexDictionary.loadBackupAsync(Object parameters) at MusicBee.Plugin.#=qq8unhGCJB9SClRVZR5gNmygFqueSbCHuuBEa3Z$$56c=(Object #=q3lUtIUSd9g6WUEwABBRV_w==)
Quote from: redwing on October 02, 2016, 08:45:12 AMQuote from: redwing on May 13, 2016, 12:18:31 PM- If there were changes, show those tags and values only on the popup window upon clicking on the command.This is what I suggested. But currently it shows all tags, not just changed tags. Then the user has to read all tags to find out what's changed.changed tags are highlighted by blue-grey color (except for artworks).
