Hey all:
I've searched this thread and didn't find an answer to this question, but if I missed something and this question is redundant, please let me know.
My question is: is there a way to append a text phrase to the "comments" field? It seems like the "copy tag" tool can append data, but I don't want to copy a tag. I want to, for example, append the text "Mix 1" to all the files I have selected, and I'd like to do so without having to first tag them somewhere as "Mix 1".
Thanks!
x
Try the following below. It will result in <Comment> foo > <Comment> foo Mix 1
It will even work in <Comment> with multiple lines, i.e.
foo 1 foo 1
foo 2 > foo 2
foo 3 foo 3 Mix 1
1) Create new Preset (add name and description)
2) Under the preset editor, for "Step 1"
Search for:
Replace with:
3) Set the tags to <Comment>
4) Press OK
5) Go back to MB and select a few files you want to edit
6) Select the new present
7) Preview
Apply and check tags
9) If happy, save all & close
NOTA BENE: Do not check the preset because if you do, it will run the preset on every file you select. So, leave it unchecked.
^EDIT NOTE: In the screenshot, " foo" under
Replace with: should be " Mix 1" (w/o quotes) to coincide with the above instructions
