Hey, i want to make use of your "TOY: 'Copy tag' command" command to copy "play count" into a custom field, ie "www radio", but im having a problem, in case of emergencies say i remove a file, or rename it, the musicbee library will reset its playcount and will copy the new tag of 0, which would delete all the previous play counts, is there anyway to use this TOY: 'Copy tag' command with an IF statement? so for example, say i delete an audio file from the library, rename it, import it back in, the www radio tag has say 53, play count in musicbee library has 0, but if the www radio tag value is higher, it copies it back to the play count tag, and continues updating the musicbee library tag, when a track is played 50% it increases by 1, and also updates the www radio tag as well
