Author Topic: Additional Tagging & Reporting Tools  (Read 970367 times)
Hi Boroda,
using the latest version of this plug in, I'm receiving this error at the completion of the reading/generating of a library totals report. it completely shuts down musicbee. Any ideas?
MusicBee v3.6.8905.12923P  (Win10.0), 26 May 2024 14:43:
System.OverflowException: TimeSpan overflowed because the duration is too long.
   at System.TimeSpan.Interval(Double value, Int32 scale)
   at MusicBeePlugin.Plugin.ConvertStringsResult.getFormattedResult(Int32 operation, String mulDivFactorRepr, String precisionDigitsRepr, String appendedText)
   at MusicBeePlugin.LibraryReports.AggregatedTags.GetField(String composedGroupings, ConvertStringsResult[] convertResults, Int32 fieldNumber, ColumnAttributesDict groupings, Int32 operation, String mulDivFactorRepr, String precisionDigitsRepr, String appendedText)
   at MusicBeePlugin.LibraryReports.applyPresetResults(String[] queriedFiles, AggregatedTags tags, SortedDictionary`2 filesActualComposedSplitGroupingTagsLists, Boolean interactive, Boolean saveResultsToTags, String functionId, Boolean filterResults)
   at MusicBeePlugin.LibraryReports.executePreset(String[] queriedFiles, Boolean interactive, Boolean saveResultsToTags, String functionId, Boolean filterResults, Boolean forceCacheUpdate)
   at MusicBeePlugin.LibraryReports.previewTrackList()
   at MusicBeePlugin.PluginWindowTemplate.serializedOperation()
   at System.Threading.ThreadHelper.ThreadStart_Context(Object state)
   at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
   at System.Threading.ThreadHelper.ThreadStart()
thanks for critical bug report. it turned out that sometimes LR was generating unreasonably huge and senseless values, e.g. i was getting billions of milliseconds for track durations using "library totals" preset. this should be fixed.
version 8.2 (for MB 3.6):
full plugin package 8.1 (for MB 3.5):
https://www.mediafire.com/file/dm3rhfze89n3qwi/Additional-Tagging-Tools-Plugin.zip/file
Dizza17
Hi Boroda,
Unfortunately still getting major error when using generating reports in LR. This is the current error log.
  MusicBee v3.6.8905.12923P  (Win10.0), 27 May 2024 13:48:
System.OutOfMemoryException: Exception of type 'System.OutOfMemoryException' was thrown.
   at System.Windows.Forms.Control.MarshaledInvoke(Control caller, Delegate method, Object[] args, Boolean synchronous)
   at System.Windows.Forms.Control.Invoke(Delegate method, Object[] args)
   at MusicBeePlugin.LibraryReports.applyOnlyGroupingsPresetResults(String[] queriedFiles, Boolean interactive, Boolean filterResults)
When the rich wage war, it’s the poor who suffer.
this is another error, and i guess another LR preset. run this debug version and post updated error message:
https://www.mediafire.com/file/odmp6wgn9hg7hfi/mb_TagTools_debug.zip/file
Dizza17
Hi Boroda,
see attached error message as requested,
MusicBee v3.6.8905.12923P  (Win10.0), 28 May 2024 16:57:
System.InvalidOperationException: Collection was modified after the enumerator was instantiated.
   at System.ThrowHelper.ThrowInvalidOperationException(ExceptionResource resource)
   at System.Collections.Generic.SortedSet`1.Enumerator.MoveNext()
   at System.Collections.Generic.SortedDictionary`2.Enumerator.MoveNext()
   at MusicBeePlugin.LibraryReports.clearArtworks() in D:\Source\Repos\Additional-Tagging-Tools\Plugin\LibraryReports.cs:line 1992
   at MusicBeePlugin.LibraryReports.resetLocalsAndUiControls() in D:\Source\Repos\Additional-Tagging-Tools\Plugin\LibraryReports.cs:line 2024
   at MusicBeePlugin.LibraryReports.presetListSelectedIndexChanged(Int32 index) in D:\Source\Repos\Additional-Tagging-Tools\Plugin\LibraryReports.cs:line 6442
   at MusicBeePlugin.LibraryReports.presetList_SelectedIndexChanged(Object sender, EventArgs e) in D:\Source\Repos\Additional-Tagging-Tools\Plugin\LibraryReports.cs:line 6426
   at System.EventHandler.Invoke(Object sender, EventArgs e)
   at System.Windows.Forms.ListBox.OnSelectedIndexChanged(EventArgs e)
   at System.Windows.Forms.CheckedListBox.OnSelectedIndexChanged(EventArgs e)
   at System.Windows.Forms.ListBox.WmReflectCommand(Message& m)
   at System.Windows.Forms.CheckedListBox.WmReflectCommand(Message& m)
   at System.Windows.Forms.ListBox.WndProc(Message& m)
   at System.Windows.Forms.CheckedListBox.WndProc(Message& m)
   at MusicBeePlugin.CustomCheckedListBox.WndProc(Message& m) in D:\Source\Repos\Additional-Tagging-Tools\Helpers\CustomControls.cs:line 1200
that's yet another error.
thank you for your testing. i've found even more LR bugs than you have, thanks to your efforts.
i believe this version should work without errors (it's still debug version, i'll recompile it in "release mode" later if all is fine now):
Dizza17
Not a problem Boroda, glad i could be of some assistance. Thank you for continuing to maintain and develop this awesome plug in.
cheers Aaron
bkev
I haven't updated the tools for a while and I've done it today with the version above but when I go to  "Tools - Additional Tagging & Reporting Tools - Advanced Search & Replace" I get a MusicBee error
MusicBee v3.5.8698.34385D  (Win10.0), 29 May 2024 15:01:
System.ArgumentNullException: Value cannot be null.
Parameter name: brush
   at System.Drawing.Graphics.FillRectangle(Brush brush, Int32 x, Int32 y, Int32 width, Int32 height)
   at System.Drawing.Graphics.FillRectangle(Brush brush, Rectangle rect)
   at MusicBeePlugin.CustomVScrollBar.OnPaint1(PaintEventArgs e, Image upArrowImage, Image downArrowImage, Image thumbTopImage, Image thumbMiddleImage, Image thumbBottomImage, Boolean stretchThumbImage)
   at MusicBeePlugin.CustomVScrollBar.OnPaint(PaintEventArgs e)
   at System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer)
   at System.Windows.Forms.Control.WmPaint(Message& m)
   at System.Windows.Forms.ContainerControl.WndProc(Message& m)
   at System.Windows.Forms.UserControl.WndProc(Message& m)
Are you certain you downloaded/installed the correct version for MB 3.5?
In MB go to Tools > Additional Tagging & Reporting Tools and see the version number at the bottom. It should be 8.1.xxxx. If it shows anything else you've got the wrong version.
bkev
Thanks for the quick reply. Initially I didn't, but I removed the files and deleted all my app data and restored back.
I checked and it worked correctly. I then put the new plug in but I get the same issue.
The version number I have is
8.1.8915.20753
i can't reproduce this bug. try to install the latest plugin version (which is 8.1.8915.27389), and the latest MB patch (download it here, unzip all files to MB folder overwriting all files).
also, you can try to delete the file "mb_TagTools.settings.xml" from MB <AppData> folder.
bkev
Still the same I'm afraid.
I've tried uninstalling Musicbee, deleted the local and roaming app data. Reinstalled and then put on the patch. Installed the 27389 version and I still get the same I'm afraid.
The plugin seems to work. Calculations work and auto presets work. The issue seems to be the scroll bars. They just show as red crosses. But I can use a scroll wheel to look at the presets.
MusicBee v3.5.8909.34013D  (Win10.0), 29 May 2024 20:08:
tjinc
Hi Boroda,
I have also seen this issue:
MusicBee v3.6.8913.35323P  (Win10.0), 29 May 2024 23:03:
This seems to happen only when these two conditions are met:
1. Plugin is set to 'Use Skin Colors' and
2. Skin being used is a light colour - e.g. MusicBee3, Sky Blue, CalciumMETRO etc. - it does not appear to be a problem with dark skins
(Hoping this might help you track the issue.)
@tjinc, thanks for detailed report. i've fixed this bug in the sense of the plugin not throwing exception anymore, but i still need to improve support for very light skins. now scroll bars are invisible, e.g. for MusicBee3 and Windows Theme (for Win10 Light mode) skins.
this version is for MB 3.5:
https://www.mediafire.com/file/pynpqaiu175g2ou/mb_TagTools.zip/file
