Author Topic: Additional Tagging & Reporting Tools  (Read 932273 times)
alec.tron
Which gives me a work around - in case this helps anyone else
Meh, called it too early. It's still happening on flac files that have been sent to library too. It's so utterly odd, altogether and that on the 10 files I randomly tested with with, sending to library seemed to bypass the issue, but now it's back when I try to run the script on files I haven't fully tagged yet.... :/
c.
new plugin beta version is released (you will need latest mb 3.5 patch or stable 3.5 mb version or later when they are released):
https://www.mediafire.com/file/9tpb95arr33qvu1/mb_TagTools_beta.zip/file
some bug fixes and probably new bugs are introduced  :)
MSR command is significantly reworked, now it can be used for very complex searching (without replacements). you can gradually refine your search by adding new rows to the search table and clicking the 'Find' button again. this command is incomplete, 'Select found' button doesn't work yet.
Last Edit: June 19, 2022, 02:56:13 PM by boroda
i've found that i've missed mb native custom search, which is almost perfect (maybe only "not" checkboxes are needed before tag names). so i've removed "search only" capability from MSR.
try  this version (i've changed plugin colors, when i was modifying MSR (and these modifications are now obsolete), but haven't tested new colors with various skins):
if you are satisfied with coloring, then i'll remove msr "search only" option from this version and upload it as new stable version.
try  this version
It doesn't look good:
Does the download contain the correct files?:
Both the dates and the version number seems off.
settings says: 5.4.8202
B.t.w.,
I never use 'use skin colours' for your plugin, since I am mainly using dark skins, and things become quite ugly/unreadable using that setting.
redownload beta version again. also what colors are you using for windows (suggest it's windows 10)?.
No visual changes or improvements.
Version now says 5.4.8205
My Windows 10 colour settings:
Last Edit: June 19, 2022, 04:50:41 PM by hiccup
That looks a lot better:
Personally I don't care much for the alternating line colouring, but that will be a matter of taste.
edit:
Besides my personal dislike for alternating row colours (a useless and distracting feature in my opinion), I am also not sure why the first line has a different (darker) background colour than the other lines?
Last Edit: June 19, 2022, 09:36:04 PM by hiccup
blue line in your screenshot is "selected" or "current" line. this line can't be edited in asr anyway, so it doesn't make much sense to highlight it, but i'm not sure if this highlighting can be easily disabled (this behavior is either default or the only one for .net "grid view" control). i'll leave it as is for now.
Last Edit: June 20, 2022, 12:59:44 AM by boroda
new stable version (minor improvements and bug fixes)
Thanks boroda.
iamambuser
Hi, just tried the new version
new stable version (minor improvements and bug fixes):
but it still vanishes after restart.
Previous post
Just updated to 3.5beta and AT&RT vanished. Clicking "configure" gives
MusicBee v3.5.8146.38239D  (Win10.0), 25 Apr 2022 8:21:
System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.NullReferenceException: Object reference not set to an instance of an object.
   at MusicBeePlugin.SettingsPlugin.InitializeComponent()
   at MusicBeePlugin.SettingsPlugin..ctor(Plugin TagToolsPluginParam, PluginInfo aboutParam)
   at MusicBeePlugin.Plugin.Configure(IntPtr panelHandle)
   at #=zFATgFjBdBS9YrWXGWg==.#=zhhGt68w=(IntPtr #=zTJWEEq3dlH_v)
Tried disabling all other plugins (last.fm (already disabled, don't use), cd art display (already disabled, don't use), lyrics reloaded, media control, taskbar tidbits, theater mode) and restarting but still no AT&RT and same error message. Tried complete uninstall (clicked uninstall, closed MB, deleted AT&RT files from plugin folder) and reinstall. Works until I restart MB and then vanishes and gives same error.
Current error message
MusicBee v3.5.8157.35511D  (Win10.0), 22 Jun 2022 10:16:
   at #=zCJ5ZapFPlFl7hsQxGA==.#=zFyIrpRo=(IntPtr #=z5gr9m3RiL7fx)
I tried deleting the settings.xml as well (https://getmusicbee.com/forum/index.php?topic=35245.0) but still AT&RT fails after restart.
do you see message "System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation" on plugin initialization (on mb startup if plugin is enabled)?
