Author Topic: Additional Tagging & Reporting Tools  (Read 930074 times)
Good info Bee-liever. I have two (three?) auto-presets. I will disable them all and see what happens.
It seems like you were able to trigger the freeze once you were using the tag editor. My freezes have come not when editing, but simply using ASR. Or sometimes just launching MB.
Thanks.
Using the working ASR I disabled the two auto-presets I had. Closed MB, copied over the latest plugin and launched MB. Used ASR to do a simple 'change case' and it locked up. Closed with Task Manager and tried again. Same thing. Replaced the new dll with the old and it now works as expected.
PM sent - thanks
yes! i can reproduce ui freezing. will look deeper now.
GREAT!
Did a quick two track test and the latest dll seems to be working without any lock-ups. I will have some time later today to test it further, but it's looking good.
I'm going to look back in this thread to see if I can find the other user who was having lock-ups and point him to this release and ask him to post here if it works for him or not.
Thanks for your time in tracking down this issue.
I'm also having problems with the latest version of the plugin and can't seem to find a link to older versions. Can you upload the version you have?
@dr0mo-
Take a look at this new version of the dll that boroda posted. No more freezes. Please give it a try and post the results here.
https://www.mediafire.com/file/lx6lk42gdeci018/mb_TagTools.dll/file
minor visual improvements (changed colors of all tables). also its full package of plugin, not just dll:
http://www.mediafire.com/file/h2t08o9562efboi/mb_TagTools_latest.zip/file
new virtual tag function added:
$AddLeadingZeros(number,number_of_didgits_including_leading_zeros): adds leading zeros to number
Follow-up... I used ASR quite a bit yesterday and had no issues whatsoever. Very glad you were able to fix it. Thank you.
  • MB Version: 3.6.8849 P
Uhmm.  Isn't that what $Pad(<field>,number) already does?
yes, you are right. i've removed this function from plugin.
dr0mo
@dr0mo-
The last version is working fine too, thanks for the help guys
