'delete' these 3 presets, manually delete all files from 'plugins\asr presets' folder, then unzip asr presets from any recent plugin zip and 'import all' presets.
@boroda...
Still not working. First off,my ASR Presets folder was under AppData not Plugins. Since it works there, I left it there.
Using the 'working' version of ASR I launched MB and deleted the three funky presets.
I closed and restarted MB and using ASR I deleted all remaining presets and closed MB.
I checked the Presets folder and they were gone, and then copied them in from a recent zip.
Launched MB and ASR (older, working version) and imported the presets and ASR worked as it always has.
Closed MB, overwrote the working dll with the most recent dll, launched MB and as soon as I tried to apply a preset, MB locked up.
Closed MB, moved the presets folder to under Plugins and it still locked up.
So 5.2.7167 still not working for me. But know I'm wondering under what folder should the presets folder be? For the time being, I have it under the plugins folder. And 5.1.7154 is working as expected. Not so good with the latest version.
I appreciate you looking at this again. Let me know if you think of anything else that might be the cause.
