Author Topic: Additional Tagging & Reporting Tools  (Read 917262 times)
  • MB Version: 3.6.8830 P
Version: 5.2.7214
Stops at 87% of second ALR preset.
Error Log:
MusicBee v3.3.7251.37421P  (Win10.0), 14 Nov 2019 15:14:
   at #=zsuw89B8ux0wjALoQ8679GTVJvpgI.#=zM0iWbZHZOpjh(#=zfPN9N9ucNejpFsmGK7Yoz5A= #=zh$Cto0o=, #=zb4zx58KH1jMbCbsRe1KWcezvMuc0[] #=zbAKnYPE=, #=zT_UiO12$HceYzJV4w2wndYU= #=zUt3Af3Y=, StringBuilder #=zKsoWZAs=)
   at #=z7R5fQlEWA_zekNPRaAFassm4KT6Y.#=zBvjBMt1tQgDq(#=zfPN9N9ucNejpFsmGK7Yoz5A= #=zh$Cto0o=, #=zT_UiO12$HceYzJV4w2wndYU= #=zUt3Af3Y=)
   at #=zfPN9N9ucNejpFsmGK7Yoz5A=.#=zhW5rhVLmgA5t(Int32 #=zlGZMpsA=, #=zT_UiO12$HceYzJV4w2wndYU= #=zUt3Af3Y=)
   at #=zfPN9N9ucNejpFsmGK7Yoz5A=.#=zvesHNF197Ki_(TagCode #=zpXMe84c=)
   at #=z78OeXVV6zcbJKhXa4Q==.#=zThGs_SKDXjKl(#=zfPN9N9ucNejpFsmGK7Yoz5A= #=zh$Cto0o=, Int32 #=zzn0Oaqw=)
   at #=z78OeXVV6zcbJKhXa4Q==.#=zuCWZmkrNFqCNSvZbsA==(String #=zesgHATI=, Int32 #=zzn0Oaqw=)
   at MusicBeePlugin.Plugin.GetFileTag(String sourceFileUrl, MetaDataType tagId, Boolean autoAlbumArtist, Boolean normalizeTrackRatingTo0_100Range)
   at MusicBeePlugin.AutoLibraryReportsCommand.previewTrackList(Boolean interactive)
   at MusicBeePlugin.AutoLibraryReportsCommand.previewTrackList()
   at MusicBeePlugin.PluginWindowTemplate.serializedOperation()
   at System.Threading.ThreadHelper.ThreadStart_Context(Object state)
   at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
   at System.Threading.ThreadHelper.ThreadStart()
Only the MusicBee Error window.
MB closes when you click 'OK'
Think the error log is exactly the same as before:
14/11/2019 3:57:14 PM - 10.0.18362.0 - 3.3.7251.37421P - System.NullReferenceException: Object reference not set to an instance of an object.
PWN3D_
Just tested version in post #2161 and did a few edits on some albums, it seems to works better for me, no more UI freezes for now. Need more testing.
Edit:Mmmh, still some freezes but they last smaller than before. The Albumart not updating in main window is still there but I guess this is minor for now.
Last Edit: November 14, 2019, 02:29:07 PM by PWN3D_
MB 3.3.7257 P and TagTools 5.2.7214 work great!
Sorry if I wasted your time, I didn't notice that Steven had posted a newer patch than the one I was using. :-[
Just tried this combination and it locked up. Killed it, restarted, waited one minute, hard freeze. Killed it, restarted, locked up within five seconds.
It seems that 5.1.7154 is the last version that works for me without locking up MB. Anything more recent than that presents a hard freeze.
phred, i'll take a more close look at your issue tomorrow.
no, its special mb patch to solve issues when using the plugin. i don't think this patch was initially planned :)
Great - thanks.
phred, do you have any alr presets? do you have asr presets ticked for auto-applying? what happens if you disable all plugins except for at&rt?
Using AT&RT 5.2.7214 with MB 3.3.7257 P
I have no presets for library reports, nor have I used reports in quite some time.
I thought I had three or four ASR presets ticked, but only found one, which I disabled. Closed MB and restarted and MB froze.
I have disabled all plugins except AT&RT, shut down and restarted MB, performed a preset (change case) and ASR showed the changes, but never displayed 'close' or 'save' and only changed one of the left side boxes changed from a tick to a solid box and promptly froze. MB's status bar shows "Changing case: 100% (2 file(s)) read" when it hangs.
Please let me know what other information I can provide in order to help get this resolved.
Thanks.
Tpyo
Newie here - 1st post
I'm here today searching for more Tagging Tools.
I'm finally moving my Playlist to a Smartphone, and I see lots of editing on the Desktop in my future. I tried a few other programs (am I suppose to say Apps now? - lol)
The final decisions to chose MB was
1) Android path too
2) Tagging Tools with a memory of existing Tags
This program appears a growth stage, seeing lots of small errors popping up
? - should I wait?
thanks
cant reproduce this and dont have any ideas why this would happen. sorry.
Thanks for taking a look at it. Since it is working with an older version, I'll keep using that until your next release and see what happens then.
