After installing the new version, running asr command first time shows this error. Next time it works. Started from a few versions ago.
at MusicBeePlugin.AdvancedSearchAndReplaceCommand.InitializeComponent()
at MusicBeePlugin.AdvancedSearchAndReplaceCommand..ctor(Plugin tagToolsPluginParam)
at MusicBeePlugin.Plugin.asrEventHandler(Object sender, EventArgs e)
This is when you run msr command first:
at MusicBeePlugin.MultipleSearchReplaceCommand.InitializeComponent()
at MusicBeePlugin.MultipleSearchReplaceCommand..ctor(Plugin tagToolsPluginParam)
at MusicBeePlugin.Plugin.multipleSearchReplaceEventHandler(Object sender, EventArgs e)
