What presets have changed? Are there any except the unicode preset?
unicode preset and all presets with 2 parameter asr functions (i've replaced , by ;; ).
The new multiple search & replace preset has a bug:
Try
*(b)/$1aa
It works fine with MSR command, but not with ASR command. So it can't be used via a hotkey.
Also, it doesn't add a proper escape sequences to special characters when they are entered via MSR command (previous versions had the same bug).
For instance enter "#" or "*" to the first box.
Then if you open the ASR preset it's saved as either "#/abc" or "*/abc" rather than "\#/abc" or "\*/abc".
