Author Topic: Edit Screen  (Read 240 times)
ParagonOpus1
F1 or right click and edit brings up nothing? why?
F1 is not a default hotkey for anything in MB.
SHIFT-ENTER is the default hotkey to open the Tag Editor. But you first have to select the files (tracks/albums) you want to edit. Or right-click > Edit
https://getmusicbee.com/forum/index.php?topic=36576.msg200511#msg200511
Last Edit: December 21, 2022, 03:00:04 AM by phred
Check out the MusicBee Wiki.
ParagonOpus1
well, not sure why that is the hotkey, but it is. If I right click on a album and select edit nothing comes up. It use to bring up all the tags; I look around to fix it and nodda.
What has happened, why can't I edit an album anymore?
Then you must've changed it yourself.
Have you looked at the list of Hotkeys?
ParagonOpus1
Ya, I don't know enough about this program to have changed anything. Just after I rebuilt my server and loaded this, the stuff is all changed and edit it no longer possible.
ParagonOpus1
Ya, this is a bug. Just found it; the screen got hidden behind another screen and then lost on my multiple monitors. Kinda annoying. I suspected this and was looking for a reset to default options, or something like that, but couldn't find it, other than starting over on my library, which I didn't want to do. Maybe pass that along to the developers.
