Author Topic: Album cover reflections missing with latest update  (Read 578 times)
CMRN
So having not updated in a long while, I decided to install the latest version tonight and noticed that the reflection effect in the Album Covers view is no longer appearing for me. After some searching in the forums, it seems that the effect was disabled for those who have 'auto-pick panel colours' disabled. However, I have that setting enabled and yet the effect is still missing.
Very curious to know if it has been removed outright or if not, why it's not appearing for me as I quite like the feature.
I guess it was removed by mistake when auto-colouring is enabled. This restores the functionality:
aktor
After I used this patch i get this error at the end of playing an album.
21.12.2022 20:31:36 - 6.1.7601.65536 - 3.5.8388.32476D - url:
#=z_B_hxdu_sic_gxg72zqot7OAiblK: Exception of type '#=z_B_hxdu_sic_gxg72zqot7OAiblK' was thrown.
   at #=z4BLR1X96NbsI9N7r4a$now0=.#=ziweROsrASwOz(Boolean #=z9j9epRsz_Lwz, #=zCOxS52q4D9l4j0EdjCcXb7o= #=z3Js83$$tukQ0, Int32 #=zhPU9Sup1FkQMrWV$Cw==)
   at #=z4BLR1X96NbsI9N7r4a$now0=.#=zEBPo6Dd5g12J(Object #=z9ov_TIU=)
if you are using Wasapi Exclusive then redownload the latest patch version
