Author Topic: Only convert lossless  (Read 508 times)
Babydoll32
couldn‘t be an option for converter be implemented, that only lossless will be converted and others be copied? As in synch options.
why just not to sync tracks with virtual device, and convert only lossless tracks on syncing?
Babydoll32
There are some reasons, where I have to do manually and I‘ve some mixed stuff playlists with MP3 & FLAC content and MP3 will reencode too, what I don‘t want.
no, mp3 won't be reencoded, only lossless will. just select "only convert files with lossless format" in virtual device settings. manual operations are not the problem too. you can right-click required tracks and select "send to> device <device name>".
