Author Topic: New router; wifi sync no longer works  (Read 342 times)
ome-reily
I'm getting an error message that states that MusicBee Sync can't connect to the server.
I'm trying to sync my Android device to Windows 10. This worked for me as recently as a couple days ago, but I had to go to the store and buy a new router for reasons.
There have been no changes/updates to my phone or PC in the meantime.
I logged into the new router and played with turning UPnP on and off. I turned the firewall on and off. I did a manual sync (fine) but wifi sync doesnt work.
I tried the old router and wifi sync worked, but in any case I can't keep using that one and I can't get the same model, either. (Please don't ask why, it's a long story, I just can't).
Anyone else have this problem or know how to fix it?
you could try clearing the cached app data for the wifi app
