Is it possible to add a bit more funcionality to the bookmarking?
Following scenario:
Audiobooks that are very long, and have only one track. 4 to 10 hours, for example.
If MusicBee can do only a start bookmark, and play from this point on, this will be very helpful.
In addition, the same behavoiur for multi track audiobooks/albums. It should work as follows:
I press a defined key shortcut or button on the screen. Then a start bookmark will be created.
Then in the bookmarks there should be one point in the context menu for the bookmark "play rest of the album from this point".
Then MusicBee plays the rest of the album/audiobook (whatever), even when it has multiple following tracks.
That would be perfect!
