Author Topic: <album duration>  (Read 556 times)
Fox63
I noticed that the album duration field has been transformed from seconds to hours and minutes, however I would have put the display format hh:mm.ss.
If the data is entered in a string the text will move when only minutes and seconds are present.
Then the single display example 3:45 could be taken for three hours and 45 minutes, if instead it was 00:03:45 there would be no doubt.
It's just a small note. Also because using a few conditions I transformed the <album duration> field with the format hh:mm:ss.
Are you talking about what's displayed in the status bar? If so, click once on it and it changes from, for example, "9:41:47" to "9.7 hours."
Fox63
Sorry, I wasn't very clear.
I was talking about the <album duration> which is displayed, for example, in the main panel, which in the latest versions no longer shows the time in seconds but in hours.
Last Edit: November 21, 2022, 10:18:29 AM by Fox63
