Using 3.5.8338 P
This one is rather mind-boggling. I've been dealing with it for about a week, through a couple versions.
I'm using Lyrics Reloaded (Latest) to grab lyrics and it's been working well. When it returns incorrect lyrics, I've found the only way to delete them is to mark them as having no lyrics and then removing the "no lyrics" mark. I have two tracks, from two different albums, from two different lyrics providers, where the lyrics appear not to be removed. All my lyrics are embedded in the music file.
The lyrics show in the lyrics panel in the right sidebar. But my "no lyrics" highlight is activated. When I look in the tag editor lyrics tab, there are no lyrics. When i look with the tag inspector, there are no lyrics. Yet they appear in the lyrics panel. Today as a test I opened the tag editor and in the lyrics tab, I typed in some text. I saved it and the lyrics highlight went away, but the lyrics showing in the panel are not what I typed in, but the lyrics that are incorrect and don't get removed. I did a file rescan with no change. I closed MB and reopened it and the test lyrics showed up. But when I marked as no lyrics and then removed the no lyrics flag, the incorrect lyrics showed up again.
I'm at a loss here and looking for some ideas as to what's going on.
Thanks.
