Author Topic: how to change panel in "now Playing"?  (Read 711 times)
Markus2310
Hey :)
I know that some weeks ago I changed some things in the grey window on the bottom of the now playing tab. But now I can't find the setting where I can edit this field... :( Can somebody help, please? :D
Best
Markus
jonap
click on the little "now playing" (the one in grey below the tabs, just above the big evanescence album picture) and then "customise panel"
Markus2310
I have another question for that panel...
Is there a way to display text on a second line in case it doesn't fit on one line? For example, "Vocals" in the screenshot:
Thanks in advance :)
karbock
@Markus2310
Yes, there is a way:
* Track Information panel -> (panel header menu) -> Customize panel...
* Change max. row span (on the right) to the desired number of rows for the corresponding field
If you have a multi-value field and want to split the values, one per row, tick the corresponding box to the right of the field name
(under split multi-value tags into rows)
Screenshot here.
Last Edit: November 04, 2022, 10:40:02 AM by karbock
Markus2310
Thank you very much, that helped a lot!
Another thing now is: Is there a way to show in the Track Information panel if a song is in a Playlist? You can choose the field "Playlist" but that doesnt have any effect.
The Incredible Boom Boom
There is not, but it would make for an interesting wishlist request.
