Author Topic: Any way to filter by Love in MusicBee?  (Read 498 times)
Impulse
Is there any way to filter all songs by love in the music library? Say I have like 1000 and I love 500 of them. Is there any way to filter my music library so I can only see those loved songs in the library? I want to be able to shuffle through all loved songs if that makes sense, without having to listen to the unloved songs. Thanks in advance
There are lots of ways to do this. One way is to create an auto-playlist where for the filter criteria you use the "Love" field and the criteria: "Is Loved"
T010
Another way is if you have a Love column in your library view, you can middle-mouse-click the love icon/column, and MB will open a new tab with only your loved items.
Alternative way with the same result is to right-click the Love column of a loved item, select "Search..." then select "Find Love L"
