I would like to specify the sample rate and bit depth when converting to WAV format. Is it possible to add custom parameters for converting files to WAV?
In Preferences > File Converters there are configuration options for most audio file types apart from WAV. If a WAV section was available I could use
ffmpeg to set the bit depth and sample rate.
