Author Topic: Custom Tab Icons  (Read 3256 times)
Orion
I don't know if it's easy to do but I have been thinking it would be great to be abble to customize tab icons (it would be particularly useful when you pin mutiple playlist tabs : currently they all share the same icon and only the text is different so you can't hide the text).
Thank you very much for you attention.
  • MB Version: 3.6.8830 P
+1
aktor
What about web links icon. Can it be customizable or an option to remove the icon.
