Author Topic: compact layout issue  (Read 274 times)
tranliem06
hey guys, i have this problem when i switched to the compact player. The artwork position in the track information tab just not working right. It would always be placed left of field even when i tried to choose Above field. Please help me.
can you post a screenshot of the compact player and also the settings you are referring to
tranliem06
Here is the screenshot, as i mentioned above the photo cover of the song should be placed above the song information field. But i kept being in the same position that is left of the field. This issue only occurs in the compact player . In normal player it works fine
The relevant settings are shared with the main player and its true only "not displayed" and "left of fields" are respected for the compact player. I am not sure if I will add in the support needed for the other layout choices
tranliem06
ok i got it. Anyway thank you for replying
