Author Topic: Can you help me to find where to change to 432 hz?  (Read 649 times)
CaptBret
Hello,
I am currently using Music Bee version 3.4.8033.
Can someone please show me where I can change the playback pitch from 440 hx to 432 hz?  I just updated MB for this reason and cannot seem to find it.
Thank you!
First I would recommend updating to the latest 3.5.x patch version by downloading it here, unzipping it directly into your MusicBee directory and letting it overwrite existing files: https://getmusicbee.com/patches/MusicBee35_Patched.zip
To access the pitch control, go to Preferences/Player and hit the Equaliser & DSP button in the lower right corner.  Then, in the DSP Plugins list, select the "Tempo Control" choice;  this will bring up a window allowing you to change either the "play speed" (Tempo), pitch, or sample rate.
For the 432 Hz effect, select pitch, type -0.32 into the semitones box, and hit OK.
CaptBret
Awesome!
Quick fix and works great.  Sounds great too!
Thank you!
