Author Topic: MusicBee Plays Multiple Tracks At Same Time  (Read 520 times)
Coogan
When skipping traks, MusicBee will occasionally begin to play multiple tracks at the same time.
I don't know if I'm skipping tracks too quickly or what.
I've PM'd Steven my Settings file.
Thanks for any help.
Last Edit: October 15, 2022, 09:27:02 PM by Coogan
My MusicBee Version:
3.5.8842
i wont have time to look at this until later but in the interim, try disabling the various sound effects: crossfade, remove silence, and add silence to see which one causes the issue
Coogan
Ok Steven.  I'll disable all those and test them one by one.
Thank you.
3.5.8842
I am not able to reproduce this with your settings file.
It might also be worth trying to disable the Mono dsp plugin as well.
Also can you clarify exactly what is going on - you skip a track and it keeps playing while the next one starts playing?
Last Edit: October 16, 2022, 04:27:58 AM by Steven
Coogan
I have disabled all effects and this still happens.  I'm trying it now with MONO disabled.
It only happens if I'm skipping multiple track in rapid succession.  This doesn't always trigger it, but this is when it happens.
I have MusicBee installed on two other PC's and it appears this is only happening on this PC. (laptop)
I'm considering a reinstall of MusicBee, I just don't want to lose my layout and settings.
3.5.8842
could you clarify this point please
Coogan
It's kinda hard for me to put into words.
I'll try to record a video of this in OBS Studio tomorrow, so I can show more detail as to what's happening.
When manually skipping tracks one at a time, using a hot-key (say 10 tracks for example) the player will start playing one of the skipped tracks and if I keep skipping tracks it will begin playing another track at the same time.
I can usually reproduce this by playing music from the Playing Tracks column and use a hot-key to skip down and up a few times.
I find it interesting that MusicBee would be able to play two tracks at the same time.
3.5.8842
No need to record a video as i get the idea. I still cant reproduce the issue though and i dont want to spend much more time on it as it doesnt sound like something people would normally do
