Author Topic: After scan confirmation  (Read 454 times)
dujuarez
I don't understand this message. Will it remove my files from my HDD? What is the program trying to do and what can I do to prevent it from happening?
Thank you.
David
What is the message you're seeing? And when? And where?
dujuarez
Sorry I thought that I had the url on the post.
https://imgur.com/a/q24pM5E
It happened after scanning. I answered no, but now I'm seeing triangle with exclamation. How can I fix this problem?
Thank you.
David
The message clearly states the the files listed are not where MB expects them to be. This could due to you deleting from using an application other than MB. Such as a file explorer. You should never move or delete files outside of MB as MB will no longer know where they are. As the message states.
Do you know if the files exist -any-where? If you know where they are you can either move them back to where they were using the File Organizer. Or you can File > Add Files to Library.
It would be nice to know if the issue was resolved.
Good to hear that.
