Author Topic: Skipping Songs  (Read 374 times)
Dalinar
Is there any way to get MusicBee to skip songs that match a certain name or pattern? I mean skip during playback
  • Heal The World
Not really, but why not create a playlist without those particular tracks?
The rule can be something like: <title> is not <whatever>
karbock
In addition to the solution Mayibongwe proposed, two more possibilities.
Let's suppose you don't want filenames containing 'foobar'.
(1) Use AutoDJ + filtering rules:
* Select the DJ tab or open it with: (New Tab) -> Playlists -> Auto DJ
* Define your source tracks
* Tick 'apply filter'
* Select 'Custom Filter...' and define your filtering rule (e.g.: Filename - does not contain - foobar)
(2) Use AutoDJ + a blacklist:
* Define an auto-playlist (say: 'Blacklist') containing ONLY all the tracks you DON'T want (e.g.: Filename - contains - foobar)
* DJ tab -> define your source tracks
* Apply filter + Custom Filter...
* Rule: Playlist - is not - Blacklist
My preferred solution is (2). Advantage: you can refine your blacklist outside the DJ tab and re-use it elsewhere.
Last Edit: October 14, 2022, 02:23:44 PM by karbock
