Author Topic: Installing the latest version  (Read 299 times)
SSK
Can I install the latest version of MusicBee over the previous version?  or should I uninstall the previous version before installing the latest version?
When I instal the latest version, do I have to re-configure my panels setting for MusicBee?
Sam
If you're using the Installer or Portable versions, simply install the new version directly over the current version. Everything will be saved. Once you install the new version, apply the latest patch available from my signature below.
