Author Topic: importing artwork  (Read 526 times)
mburton603
I just imported my mediamonkey library into musicbee, but the artwork didn't seem to be copied. Each album is in a separate folder and the album artwork is in a file named folder.jpg in each folder. How do I get musicbee to recognize these files?
Welcome to MusicBee, and to the forum mburton603
The MusicBee forum exists for more than 10 years now, it containing near 150.000 posts.
The answer to your question should easily be found after performing some forum search, or putting in a little time and effort to learn how to configure MusicBee so it does what you are requiring.
I would suggest to do that before starting yet another thread.
