Author Topic: Scrobble tracks to last.fm based on track play percentage  (Read 1720 times)
apogee_surfer
Hello, Steven.
It would be very nice to have a toggleable, configurable feature that will allow or forbid Bee to send information about the track played to last.fm, if the track was skipped halfway through.
For example, if the track has been fully listened to, then most likely you liked it and it will be sent to last.fm. If the track has been listened to only partially, then the information about the listened track will not be sent to last.fm.
last.fm makes recommendations based mostly on tracks that I listened to partially and skipped because I didn't like them.
I'm not a programmer, just a suggestion:
Get track track length > get track played time > calculate the percentage > if 60% (75 or 90 (user preference)) percent of the track was listened to, then send the track information to last.fm > else skip.
Thank you! MusicBee ist the best!
I don't use last.fm but take a look at Preferences > Now Playing > playback > skip count /play count.
Perhaps that will accomplish what you're looking for.
apogee_surfer
Missed it... And it actually works for me!
Thank you!
Thank you!
You're welcome. Glad it was an easy solution.
