Hello Steven.
Coming from:
https://getmusicbee.com/forum/index.php?topic=36952.msg204965#msg204965It appears that when providers from different lyric plugins are auto-loaded by MusicBee (during plugin activation), there is some cross-association that happens between the plugins.
Scenario:
- I have opened MusicBee with both LyricsReloaded and NeteaseLyrics disabled.
- I then go into Preferences and enable each of them.
- Having done that, MusicBee will automatically load all the different providers that each plugin has to offer.
- After running a lyrics search for a particular track, I then go on to examine the Reloaded log file.
- In it, will be this entry that indicates MusicBee has somehow associated Netease Lyrics (as a provider) with the Reloaded plugin:
02-10-2022 01:11:14 [DEBUG] Lyrics request: Julie Bergan - All Hours - All Hours - Single - Netease Cloud Music(网易云音乐)
02-10-2022 01:11:14 [WARN] The provider Netease Cloud Music(网易云音乐) was not found!
In my testing, I have tried enabling all these lyrics plugins at the same time (Reloaded, Netease, Beenius, Petit), and the conclusion is the same:
For some reason, MusicBee is associating those other providers with Reloaded according to its log file.
These other plugins do not seem to have log files, so there's no way I can verify whether they also get associated with Reloaded providers or not.
And while this doesn't seem to affect the Reloaded providers on my system, it seems to affect them for other users.
Maybe there is more to it than MusicBee just trying to run a lyrics search, from another plugin's provider, on another plugin.
Just thought I'd report this and you'd have a look.
